#1 2013-11-20 09:58
carib909
What's wrong with this Pascal Script?
  FileName := CalculateMetaTag(FilePath, 'Title');
Nothing happens when I preview or rename the files?
#2 2013-11-20 11:32
Re: What's wrong with this Pascal Script?
There is no meta tag with a name "Title".
You can see the full list of available meta tags from the Insert Meta Tag dialog in the Insert rule or in Meta Tags article on the Wiki. For example, if you are trying to extract a title of a song from WMA file, you should use "WMA_Title" tag.
#3 2013-11-20 21:52
carib909
Thank you for that.  Should I  use id3_title  for mp3's?
Also,  when I  replace  the FilePath  variable  with the actual path, I  get an error message  about the drive letter not being recognized.
When I  reply,   I get an error  message from your board saying  I'm not allowed to post url's. I'm not posting url's!   You did in your response. I  had to delete most of your message so I could reply.
#4 2013-11-21 11:57
Yes. MP3 files use ID3 tagging system, so you should use ID3_* tags for these files.
Please post the line of code that causes the error, so I can inspect it.
It is one of the measures against spam bots which prevents new users from posting links. As soon as you make 10 posts you will be automatically moved to a group that is allowed to post links. When you quoted my message you included the link from it into your response, so the anti-spam measure kicked in.
Sorry for the inconvenience. We are trying to do everything possible to keep this forum free of spam.
