#1 2007-03-17 10:39
MyComputer
Move pattern to start (prefix)
Hi
I hope you can help, I'm trying to do the following, using these file examples:
I want to move "-1", "-10" etc to the start and swap the "-" and the "n" so I end up like this:
Is this possible.
Many thanks for a very useful program.
#2 2007-03-18 12:53
Re: Move pattern to start (prefix)
Yes, it is possible, and a similar problem has been discussed in this topic: Swapping words within a file name.
You need to use Regular Expressions, and here are the parameters:
Expression: (.*)-(.*)
Replace: $2-$1
Skip Extension: Yes
This will swap to parts separated with the dash. Good Luck! smile
