#1 2013-09-24 13:36
IBIT.ZEE
Option to disable hotkey to return from stealth mode
Hi Dennis,
Nice little tool, very handy for history record in the .log file
2 issues:
    I'm having a problem of the hotkey clash with other hotkeys...
    And also beeing mistakenly activated by the user some times...
this will also be quickly resolved with a option to disable the hot key ;-) tongue roll
also a future option to change the hot key will be useful in some situations... cool
Thanks again
ZEE
#2 2013-09-24 20:09
Re: Option to disable hotkey to return from stealth mode
Hi Zee,
If I add an option to disable the hotkey then it won't be possible bring Hooker out of the stealth mode.
Hooker tries to register 4 hotkeys: Ctrl+Alt+Shift + F9, F10, F11, F12. So to allow other programs take up some of the designated hotkeys if they are started earlier than Hooker and hopefully still leave at least one hotkey for Hooker.
However, an option to change the hotkey could be easily implemented. This option could replace the standard hotkeys with a user defined hotkey, when activated, achieving both of your objectives. I like it.
#3 2013-09-25 07:04
Just a idea: how about a start parameter to "bring Hooker out of the stealth mode"?
Like C:\>hooker.exe /show
Or just start hooker a second time to show it again?
IF hooker is already running then show it
ELSE start hooker
No hotkeys needed at all.
#4 2013-09-25 10:26
@Stefan
I like it! And this could be implemented in addition to the options suggested above, allowing us to completely disable hotkeys.
