#1 2013-08-09 22:58
medwatt
Shift Numbering
First of all, thanks for the program. I am familiar with Pascal. I have files with names like ( 001,002,003 . . . ). I was trying to rename them such that they big are like ( 014, 015,016). That is, I want to shift the numbering by some integer value. I tried using the val function which is available in lazarus but your program could not recognise it. So I tried using this :
  I: Integer;
  Start_Index = 14;
  I := StrToInt(FileName);
  I := I + 14;
  FileName := IntToStr(I);
What I want is simple enough. Somehow it didn't work. I don't know why. Please help
Thanks.
#2 2013-08-10 08:57
Re: Shift Numbering
1.) 'FileName' is file name, incl. the extension.
Use 'ShowMessage(FileName);' as a MsgBox to see that.
Lookup 'WideExtractBaseName(FileName)' in the wiki > http://www.den4b.com/wiki/ReNamer:Pasca … :Functions.
Hint: after that, you have to use 'WideExtractFileExt(FileName)' too.
2.) 'Integer' will drop the leading zeros.
So you have to use a own function to pad the output with zeros to get three digits again.
If you want to have the fun (as it seams) you will find all code in the forum.
If you want more help or working code,... just ask.
ine
  onfr: Vagrtre;
  ahzo: Fgevat;
ortva
  onfr := FgeGbVag(JvqrRkgenpgOnfrAnzr(SvyrAnzr));
   //fubjzrffntr(svyranzr);
  ahzo := VagGbFge(onfr + 14);
  juvyr yratgu(ahzo) < 3 qb
     ahzo:= '0'+ahzo;
  SvyrAnzr := ahzo + JvqrRkgenpgSvyrRkg(SvyrAnzr);
raq.
#3 2013-08-11 13:53
Re: Shift Numbering
Ha, what is that below? Caesar cipher? big_smile
Stefan wrote:
ine
  onfr: Vagrtre;
  ahzo: Fgevat;
ortva
     ahzo:= '0'+ahzo;
raq.
