#1 2013-08-03 16:42
miserable
Perform action(s) after file move?
Is it currently possible to use Shutter to perform actions after a file move operation is complete? I often move files from my PC to another one on my LAN, which can take quite awhile, and would like to have my PC automatically sleep/shut down when the file move is complete.
I tried the "File Size Limit" event, but if "Trigger when size reaches" is set to 0, the actions are triggered immediately, because 0 simply directs Shutter to detect file existence.
Setting "Trigger when size reaches" to 1 byte doesn't work, for obvious reasons.
I don't think Shutter supports this type of operation, so I guess this is a suggestion to make it possible to use "-1" for the "Trigger when size reaches" setting, to detect when the specified file no longer exists.
Thanks for reading!
#2 2013-08-07 15:36
Re: Perform action(s) after file move?
I like your idea, and using "-1" value will fit nicely into the current event design.
I've added it to the list for future development.
#3 2014-06-26 17:08
miserable
Thanks for considering my idea. Do you still plan to add this function? smile
#4 2014-06-27 08:33
#5 2014-06-27 16:57
miserable
Thank you!
