#1 2013-06-08 18:58
Shutter 3.1 released!
After years of no major releases Shutter 3.1 finally brings a completely new design of the application and a much improved workflow with an ability to monitor any number of events and execute any number of actions. The set of available events and actions has been greatly expanded and improved, plus, the much desired "Protection" feature was added which can prevent unauthorized access to Shutter.
Download the latest Shutter 3.1!
Below is a full list of more than 70 changes:
* Replaced the use of DragAcceptFiles with WS_EX_ACCEPTFILES in all forms;
* Added "GB" option to File Size Limit event;
* Radio option labels are clickable on the Web Interface;
* Converted remaining constant strings to translatable resource strings;
* Translation field in the About dialog became more apparent;
* Built-in registration facility and Terms of Use dialog;
* Changed how "Always on top" option is applied, it now requires a restart;
* Words used in event status and statements are now translatable;
* Added "Lid" event which allows monitoring of lid opening and closing events;
  This event is supported only on Vista and later versions of Windows!
* Updated wildcard hint to include [ and ] for character sets;
* Volume mute/unmute action now works on Windows Vista and higher;
* Logic names added to resource strings for translation;
* Added ability to monitor when specified process starts;
* Added ability to monitor when specified window opens;
* Renamed events "Process Stops" and "Windows Closes";
* Rearranged Help menu for better readability;
* Tray icon tip will display event status if not more than one event is running,
  otherwise, general status with running time will be displayed;
* Contact email address have been updated;
* Sleep and Hibernate actions are not longer marked as Terminal;
* About dialog got a new color scheme;
* Added Above and Below choice for the CPU Usage event;
* Added "Exit application" button to the Message action dialog;
* Added Utilities action with options to close application, restart events
  and pause execution, eliminating the need for similar global options;
* Added "click to add" overlay hints for tables;
* Logic is stored as text instead of integer value in presets;
* Logic "ALL" will continuously monitor events instead of restarting them periodically;
* New API will be used for detecting user inactivity on Windows 2000 and higher;
* Improvements to thread safety procedures in Inactivity library;
* All calls to help files and web links will be verbose on error;
* Added legal notice in the about dialog;
* Improvements to Inactivity library to better handle multiple instances,
  thread safe operations;
* "User Inactive" event will work independently for all instances;
* "On Time" event is now tracking the destination time as opposed to
  using a countdown technique, making it resilient to time changes;
* All time related settings are stored in HH:MM:SS format in presets;
* All date-time pickers have been replaced by 3-part time fields;
* Power broadcast message handler returns 1 as recommended by MSDN;
* Time interval limit is increased for the Message action;
* New About dialog, list of changes moved to a text file;
* Completely redesigned application to allow usage of multiple events/actions!
* Presets: ability to save and load custom sets of events and actions!
* Process Stops and Window Closes events get configurable intervals;
* Options to actions: Message, Hang Up, Play Sound, Run Program, Close Window;
* Supported autorun of multiple copies of application;
* Added 2 new events: Network Usage and Screen Saver;
* Added 2 new actions: Open File and Kill Process;
* Added Protection settings, to restrict access to the application;
* Ability to set logic for execution of events: AND, OR, 1BY1, ALL;
* Ability to create links to all presets and configureless actions;
* Updated Inactivity.dll to allow multiple instance of User Inactive event;
* Some configuration windows are able to handle dropped files;
* Application's task bar is visible when main window is shown;
* Added 500ms waiting time before turning off the monitor;
* Positioning and size of the main windows are remembered;
* Added option to allow only one instance of the application;
* Added "Force critical" and "Disable wake event" options to Sleep/Hibernate;
* Added file size types and browse button to the File Size Limit event;
* Added option to disable balloon notification messages at tray icon;
* Added "Disable restart button" option to the Message action;
* Added option to increase the font size of content in tables;
* Mute/Unmute actions are now done via TAudioMixer component;
* Added Now button to execute actions immediately;
* Alarm action now has a proper alarm sound;
* All passwords are stored as secured MD5 hashes;
* Cleaned up and improved threaded ping functions;
* Added "Kill Process" option to the web interface;
* Web interface headers and pages now include "no-cache";
* Web interface has an ability to start up presets;
* Alarm window is flashing and making beeps;
* Countdown event is no longer limited to 24 hours;
* Main window snaps to the screen edges;
* Updated web interface html pages;
