#1 2013-05-21 02:41
eR@SeR
Synchronize filenames in different file paths
I need a script to synchronize filenames in different file paths i.e. drives (D:\, F:\, G:\...). To recognize which ones to rename, conditions are:
- same file size in bytes
- same extension
- or same CRC (if possible)
- skip renaming of same filenames
Those files would be added in files table and compared. If in one drive are two or more identical files give an error and/or ignore renaming. To determine direction of synchronizing filenames, create and point the line in code so user can choose direction.
Upper line in script renames/gives lower one new filenames. Could be G:\ gives D:\ new filenames...
Examples:
D:\Movies\Salt 2010\Noir.nfo    3,986
D:\Movies\Salt 2010\Salt.2010.R5.LiNE.Xvid {1337x}-Noir.avi    735,872,924
D:\Movies\Salt 2010\Salt.2010.R5.LiNE.Xvid {1337x}-Noir.srt    58,703
becomes
G:\Movies\Salt 2010\1337x.Org.txt    26
G:\Movies\Salt 2010\Blazinseedboxes.com.txt    83
G:\Movies\Salt 2010\Noir.nfo    3,986    --->   (ignored)
G:\Movies\Salt 2010\Salt [2010].srt    58,703    --->   Salt.2010.R5.LiNE.Xvid {1337x}-Noir.srt    58,703
G:\Movies\Salt 2010\Salt.2010.R5.LiNE.Xvid {1337x}-Noir.avi    735,872,924    --->   (ignored)
Note: files don't have to be in same path as here!
I hope that I described everything... smile
#2 2013-05-21 21:27
Re: Synchronize filenames in different file paths
This is one tricky task... Anyhow, below is a script to get you going.
The script will check for each file, extract the path without the ORIGIN to construct the target path in TARGET. Then, it will enumerate all files in the target path with the same extension as the original file and detect a file that has a different filename but the same size. A dialog is displayed to confirm the paths and when confirmed by user the matching file in TARGET is renamed to match the filename in ORIGIN.
  ORIGIN = 'D:\Temp\CopyA\';  // can be 'C:\'
  TARGET = 'D:\Temp\CopyB\';  // can be 'D:\'
  VariablePath: WideString;
  TargetPath: WideString;
  TargetMask: WideString;
  TargetRenamePath: WideString;
  Files: TStringsArray;
  I: Integer;
  Prompt: WideString;
  // check that filename matches our origin
  if WideSameText(ORIGIN, WideCopy(FilePath, 1, WideLength(ORIGIN))) then
    // prepare target path, target mask, and target rename path
    VariablePath := WideCopy(WideExtractFilePath(FilePath),
      WideLength(ORIGIN) + 1, WideLength(FilePath) - WideLength(ORIGIN));
    TargetPath := TARGET + VariablePath;
    TargetMask := '*' + WideExtractFileExt(FilePath);
    TargetRenamePath := TargetPath + WideExtractFileName(FilePath);
    // find all files in target path matching target mask
    SetLength(Files, 0);
    WideScanDirForFiles(TargetPath, Files, False, False, False, TargetMask);
    for I := 0 to Length(Files) - 1 do
      // skip files with identical filename
      if not WideSameText(WideExtractFileName(Files[i]), WideExtractFileName(FilePath)) then
        // skip files with different sizes
        if WideFileSize(Files[i]) = WideFileSize(FilePath) then
          // found matching file, confirm and rename
          Prompt := 'Found two matching files:' + #13#13 + FilePath + #13 + Files[i] +
            #13#13 + '...rename matching file to?' + #13#13 + TargetRenamePath;
          if WideDialogYesNo(Prompt) then
            // rename target file
            WideRenameFile(Files[i], TargetRenamePath);
          // stop processing other matching files, just in case
          Break;
#3 2013-05-22 03:59
eR@SeR
That was/could be the issue in case we have a lots of files. Dialog has Yes and No buttons. There is no way to cancel dialog, even cannot close ReNamer. Better solution is to see regular preview in files table, then hit Rename roll
Nevertheless I successfully synchronized filenames. Thank you smile
P.S. Cannot sort list by path and filename so I can see changes more clearly. Is it possible to do that somehow?
D:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.avi
D:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.nfo
D:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.srt
D:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.sub
D:\Movies\Alice In Wonderland\Alice.in.Wonderland.DVDRip.XviD-DiAMOND.avi
D:\Movies\Alice In Wonderland\Alice.in.Wonderland.DVDRip.XviD-DiAMOND.srt
G:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.avi
G:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.nfo
G:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.srt
G:\Movies\Ali [2001]\Ali[2001]DvDrip[Eng]-prithwi.sub
G:\Movies\Alice In Wonderland\Alice.in.Wonderland.DVDRip.XviD-DiAMOND.avi
G:\Movies\Alice In Wonderland\Alice.in.Wonderland.DVDRip.XviD-DiAMOND.srt
to be
