#1 2013-04-22 03:24
zukster
Shorten names, Strip Space and Capitalize Next
Here's a good one I could not figure out.
I have an mp3 car deck and it only displays 12 characters or so. So I wanted to change something like
Happy to Meet.mp3
with HappyToMeet.mp3 to conserve space.
So how do I change space-letter to nospace-capitalletter?
Even better would be a smart algorithm that would take a given sentence and shink it as best as possible to a specified length, but that sounds more AI involved...
So it would get changed to something like this if you specified 12.
Hapy2Meet.mp3
#2 2013-04-22 07:48
Re: Shorten names, Strip Space and Capitalize Next
Happy to Meet.mp3
HappyToMeet.mp3
DO two rules:
1. add an Case rule and Capitalise Every Word
2. add an Remove rule to remove blanks
Then click at the Preview button to see if it works.
http://www.den4b.com/wiki/ReNamer:Rules:Case
http://www.den4b.com/wiki/ReNamer:Rules:Remove
Furthermore you could do something like this:
Happy to Meet featuring Matty (bar remix).mp3
Hapy2MetFeatMaty(BarRmx).mp3
DO:
1) RegEx: Replace expression "(.)\1" with "$1" (skip extension) //To Remove Doubled Chars: 'pp' > 'p'
2) Replace: Replace all "Featuring" with "feat", "Remix" with "RMX", "to" with "2" (skip extension)
3) Case: Capitalize every word (skip extension)
4) Remove: Remove all " " (skip extension)
I hope you get the idea?
#3 2013-04-22 22:59
For converting from "HappyToMeet.mp3" to "Happy to Meet.mp3" you can use CleanUp rule with "Insert space in front of capitals" option.
#4 2013-05-01 19:46
zukster
Yes I get the idea. Thanks a lot.
That will help a great deal. I'll do most of what you suggest and then finish with a truncation rule.
When you have so many options to apply its amazing how many ways you can accomplish what you want.
Great program Den4b!
