I guess such an option to move / copy files automatically after renaming is not available, right?
Such answers can be found by searching the forum or the wiki
http://www.den4b.com/wiki/ReNamer:Renam … her_folder
You can even use PascalScript to COPY a file, but that's kind of unsupported due to side effects for average users,
you have to do this on your own. Search the forum for more help. Or someone other want to open that can of worms?
If you even have to ask,... best follow the advise from wiki link above ;-)
If you even have to ask,... best follow the advise from wiki link above ;-).
I think you must have forgotten about the function WideCopyFile
http://www.den4b.com/wiki/ReNamer:Pasca … :Functions
<<<<<You can even use PascalScript to COPY a file, but that's kind of unsupported due to side effects for average users,
Many thanks Stefan, yes, I assume, that link should be enough.
<<<<<I think you must have forgotten about the function WideCopyFile
Thanks for the link, as there are any facilities available with me, also regarding Pascal, I am very satisfied with the first link.
Thanks again.
