#1 2006-06-06 13:32
revan
Help with renamer please
I have a lot of files of format "Name XXX [0001].jpg" and want to rename them with "0001 - Name XXX.jpg" (the names are different from each others and i want to maintain that) and so on but i can't understand if this could be done with this (very nice) program and what rules to apply.
Any suggestion, please? smile
#2 2006-06-06 15:03
Re: Help with renamer please
You can do that in two different ways: using RegEx rule, and using PascalScript rule.
I'll explain the first one... Add RegEx rule and set it up like here:
Expression: ([^\[]*) (.*)
Replace: $2 - $1
I have tested it with "Name XXX [0001].jpg" and it produces "[0001] - Name XXX.jpg",
after applying the RegEx rule. So the last thing you need to do is to strip the [] brackets.
And don't forget to skip extension in the RegEx rule smile
#3 2006-06-06 15:09
revan
It Works!!! yikes
Thank you very much!!! smile
#4 2008-02-27 22:10
krtek
If we would like to do the task in one step RegEx should be like that:
Expression: (.+)\[(.+)\]
Replace: $2 - $1
Or that:
Expression: (.+)\[(\d+)\]
Replace: $2 - $1
if it's important to check if there are only digits in the square brackets.
