#1 2012-12-04 05:32
erm00
Add number to leading digits for a group of files
Hi, my name is "Moon, Tae bu".
I have a question.
before
01 Mattew01 Chapter.txt
01 Mattew02 Chapter.txt
02 Mark01 Chapter.txt
02 Mark02 Chapter.txt
03 Nuke01 Chapter.txt
03 Nuke02 Chapter.txt
23 Revelation21 chapter.txt
24 Revelation22 chapter.txt
after
40 Mattew01 Chapter.txt
40 Mattew02 Chapter.txt
41 Mark01 Chapter.txt
41 Mark02 Chapter.txt
42 Nuke01 Chapter.txt
42 Nuke02 Chapter.txt
66 Revelation21 chapter.txt
66 Revelation22 chapter.txt
How can do this???
Changed subject from:
Script? Regex?
ReNamer: add number to leading digits for a group of files
#2 2012-12-04 07:09
Re: Add number to leading digits for a group of files
Hi Tae bu, welcome!
MTb> How can do this???
1- Remove the first two signs.
.. Mattew02 Chapter.txt
2- Do an new serializing, prefix, start at 40.
Or are the serials not progressional?
Do you have to do the math on each name?
But what is the rule then?
40 - 01 =39
42 - 03 =39
66 - 23 =43, so your '66' should be '62', isn't it?
#3 2012-12-04 09:11
erm00
Hi, Stefan,
thanks for my question.
oh no, I'm sorry wrong  Question.
01+39 = 40
02+39 = 41
03+39 = 42
26+39 = 65
27+39 = 66
do this code.
How can this code? regex? script?
#4 2012-12-04 10:14
erm00 wrote:
Hi, Stefan,
01+39 = 40
02+39 = 41
03+39 = 42
26+39 = 65
27+39 = 66
do this code.
1.)
2.)
Will this work?
Do you need more step-by-step advise?
#5 2012-12-04 11:30
erm00
oh, stepan thanks...
but, i don't want to this answer
no more step-by-step advice.
i know remove rules and prefix rules.
but this way to 27 times again again...
i don't want a 27 times again.
i want this code 1 time for script or regex.
Thank you Listen to my question.
#6 2012-12-04 12:12
You have to do this two steps only one time, not 27 times.
Or do you talk about several sub folders?
Are those files not all in one single folder?
At the moment I can not understand what you want.
Please describe more accurate.
Maybe you can provide an link to an screenshot?
Or mention your mother language, perhaps some other user can help and translate.
Or utilize g00gle translator, it should be good enough for us.
The same in Korean
이 두 단계 ... 단지 한 번이 아닌 27 배를해야합니다.
또는 여러 개의 하위 폴더에 대해 이야기합니까?
이러한 파일은 모든 하나의 폴더에 있습니까?
현재 당신이 원하는 일을 이해 할 수 없습니다.
더 정확한 설명을 입력하세요.
아마 당신은 스크린 샷에 링크를 제공 할 수 있습니까?
아니면 다른 사용자가 도움 번역 할 수 있습니다, 네 엄마 언어를 언급.
또는 g00gle 번역기를 활용, 우리 충분해야합니다.
#7 2012-12-05 05:08
erm00
Hi, Stefan
ok, your Answer
https://docs.google.com/open?id=0B-mUMw … WZNdWdackE
your Answer
my, want
https://docs.google.com/open?id=0B-mUMw … 3RCUmFJTG8
my Want
Please, Help me Stefan ㅠㅠ
#8 2012-12-06 21:11
Ahh now i get it.
You have groups of files which all starts with the same number.
So we can not just serialize in sequence each after the other.
You just want to exchange the leading number by an number count-up with 39.
01 name.exe
21 name.exe
36 name.exe
TO +39:
40 name.exe
60 name.exe
75 name.exe
01 file name 01.ext
01 file name 02.ext
01 file name 03.ext
01 file name 04.ext
02 file name 01.ext
02 file name 02.ext
02 file name 03.ext
02 file name 04.ext
03 file name 01.ext
03 file name 02.ext
03 file name 03.ext
03 file name 04.ext
40 file name 01.ext
40 file name 02.ext
40 file name 03.ext
40 file name 04.ext
41 file name 01.ext
41 file name 02.ext
41 file name 03.ext
41 file name 04.ext
42 file name 01.ext
42 file name 02.ext
42 file name 03.ext
42 file name 04.ext
DO:
use this PascalScript with den4b ReNamer
Calculate_Number_Based_on_Digit_in_filename.pas
SubPatterns: TStringsArray;
Begin
   //RegEx: match leading digits, then space and anything else
   SubPatterns:=SubMatchesRegEx(FileName,'^(\d+)( .*)$',false);
   if Length(SubPatterns) <=0 then exit;
   //compose new FileName: add '39' to found number, then add the second sub-match
   FileName := IntToStr(StrToInt(SubPatterns[0]) + 39) + SubPatterns[1];
End.
(see our wiki for an howto using rules and scripts ReNamer:Rules:PascalScript)
HTH? big_smile
If yes, see my signature if you are able to help Denis too, thanks.
Find me: Calculate Number Based on Digit in filename do the math count up compute
#9 2012-12-07 05:44
erm00
Oh! Oh! big_smile
I want answers.
Thank you, Stefan.:cool:
