#1 2012-11-21 08:35
Rusherman
How to Delete Date from file name
I want to delete the date from some of my file names as in
file 2003 name.ext To read file name.ext.
I don't think there is any wild card just for numbers which would help me here.
Can anyone give me a hand pointing in the right direction on this please?
#2 2012-11-21 10:46
Re: How to Delete Date from file name
For your example
file 2003 name.ext
file name.ext
you can use "Strip" and "CleanUp" rules.
#3 2012-11-21 18:52
Rusherman
Thank you Stefan. I was so locked into wild cards that I never considered the strip command. I hate to keep bothering you but how would I have it strip only groups of four digits. There may be other numbers that I want to keep in that are less than four digits.
#4 2012-11-21 20:44
That depends on your file names. You have to find an common pattern.
Without real world examples i have no glue.
The simplest one is an regular expression like
Express: (.*) (\d\d\d\d) (.*)
Replace: $1 $3
but if that works correct for all files depends on the name pattern of that files.
f.ex. this above works only for
file 1234 name.txt
but not for
1234 name.txt
file 1234.txt
To work more universal i would try an PascalScript which can test for all three possibles at ones:
  Parts: TStringsArray;
  Base, Exte: WideString;
  Base := WideExtractBaseName(FileName);
  Exte := WideExtractFileExt(FileName);
  //try for file 1234 name.txt
  Parts := SubMatchesRegEx(Base, '(.+)( \d\d\d\d)(.+)', FALSE);
  If (Length(Parts) = 3)Then
    FileName := Parts[0] + Parts[2] + Exte;
    Exit;
  End;
  //try for 1234 name.txt
  Parts := SubMatchesRegEx(Base, '(\d\d\d\d )(.+)', FALSE);
  If (Length(Parts) = 2)Then
    FileName := Parts[1] + Exte;
    Exit;
  End;
  //try for file 1234.txt
  Parts := SubMatchesRegEx(Base, '(.+)( \d\d\d\d)', FALSE);
    FileName := Parts[0] + Exte;
    Exit;
  End;
See our wiki for an how-to work with PascalScript rules.
#5 2012-11-22 00:31
Rusherman
Thank you again Stefan. The Pascalscript, along with strip command being run before it does the trick quite nicely. It takes out the date and leaves my series numbers untouched.
