#1 2006-05-31 17:30
aethicus
Help on Syntax and placeholder/wildcards please
ok the renamer tool looks great, but i am in need of some help (read: doc)
Basically I want to do stuff like change a bunch of files that are A1[1].txt, a1[2].txt, etc to A1.htm, A2.htm
so I am looking for things like match any number or remove the [*] where "*" is a number.
also building filenames with dates or auto increment with 4 positions for the number starting at 0001 and increment by 5.
so A00001.jpg, A02312321.jpg become A0001.jpg, A0005.jpg, etc
thanks!!!
#2 2006-06-01 11:26
Re: Help on Syntax and placeholder/wildcards please
Here is the solution to the first problem:
1) Extension - htm
2) Case - All upper
3) CleanUp - strip contents of [..]
4) Strip - digits
5) Serialize - from 1 step 1 at suffix (skip extension)
Just make sure that filenames don't clash, ReNamer would give a warning,
then you would need to have a look at this topic to fix it:
http://www.redbrick.dcu.ie/~den4b/forum/index.php?forum=2&topic=8
The second problem... well, I don't see any problem there wink
Just strip all the digits, and use Serialize rule with a "step = 5",
and read the topic above if your filenames collide...
Tell us how it goes, ok? smile
