#1 2007-01-29 20:09
Icester
PascalScript to create ParentDir--Dir--FileName
Here is a little PascalScript that I wrote that parses out the Directory and Parent Directory and renames the file to ParentDirectory---Directory---FileName.  This is really handy when you use Windows search and have a bunch of 'same type' files in a bunch of different folders.
For example, suppose you have:
C:\dir_aa\dir_bb\dir_cc\myfile.txt
It would rename it to
dir_bb---dir_cc---myfile.txt
Then it is easy to apply the built in rules to remove/change the 3 delimited pieces of the filename.
By the way, double thumbs up to PascalScript.  I've never used it before, but it is very powerful.  **Thank you** so much for adding this feature to Renamer.  Now it is possible to do almost renaming task!
  Folder, Name, FName, FFName : String;
  start, h0, h1, h2, h3 : Integer;
  flag : Integer;
  delim : String;
  delim := '---';
  flag := 1;
  Folder := WideExtractFileDir(FilePath);
  start := 0;
  while (flag = 1) do
     h0 := WidePosEx('\',Folder,start+1);
     h1 := WidePosEx('\',Folder,h0+1);
     h2 := WidePosEx('\',Folder,h1+1);
     h3 := WidePosEx('\',Folder,h2+1);
     start := h1;
     if (h2 > 0) and (h3 = 0) then
        FFName := Copy(Folder, h1+1, h2-h1-1);
        FName := Copy(Folder, h2+1, Length(Folder)-1);
        flag := 0;
  Name := WideExtractFileName(Folder);
  FileName := FFName + delim + FName + delim + Name;
#2 2007-01-30 00:11
Re: PascalScript to create ParentDir--Dir--FileName
I decided to give your script a try, but unfortunately it didn't work... Anyway, this operation could be done using a much simpler script!  You will need latest development version: ReNamerBeta.zip. Script below will work on any layers of subfolders, inserting them in the new name, separating with a delimiter:
  DELIM = '---';
  I: Integer;
  Folders: TStringsArray;
  Folders := WideSplitString(WideExtractFileDir(FilePath), '\');
  for I:=Length(Folders)-1 downto 1 do
    FileName := Folders[i] + DELIM + FileName;
Enjoy smile
#3 2007-01-30 13:17
Icester
Did the files you were testing it on reside at least down 3 directories?  I could see where that could make it fail.  Moot point anyways, your script is MUCH nicer.
Thanks.  I never object to improvements. smile
#4 2007-01-31 09:14
Yep, I might have tested with a wrong number of folders.. big_smile
