#1 2012-11-06 08:42
damike
How come cpu speed MHz drops below pstates
I was just wondering what does the current cpu speed (mhz) drops below the minimum pstate? Is this the c1 state or something else?
#2 2012-11-06 12:22
Re: How come cpu speed MHz drops below pstates
Hi, welcome. What application are you talking about? Which version? On which OS?
#3 2012-11-06 22:30
damike
cpumon 1.60 on windows xp x86
#4 2012-11-06 23:04
CPU speed is calculated in real-time and it will always vary slightly depending on the load of the system and other introduced latencies.
#5 2012-11-07 08:21
damike
ok cool, so the mhz is the apparent speed of the cpu, which is different from the actual speed like the one given in cpu-z. So when it drops to something very low like 30 mhz, it is not an actual pstate. Thanks!
