Hi there. I figured out how to rename folders, and even to replace words. I just need help in numbering some mp3s. From 01-09, then 10-55. I can't figure that out. Help me please!!!
I guess that you have 55 mp3 files, and you simply want to insert 01-55 numbers into them, right? Well, add Serialize rule, then specify Incremental serialization, Index Starts = 1, and don't forget to specify Pad To Length = 2 (that will make sure that 0's appear for 01..09). More detailed description would help... Good luck!
HEY!!!! I FIGURED IT OUT. I SINCERELY APPRECIATE YOUR PROMPT RESPONSE. THANKS DEN4B.
