#1 2007-01-14 13:38
Loulia
Rename file formating date expression (yyyy-dd-mm to dd-mm-yyyy)
Hello and thanks for this wonderful software.
I have a lot of word files named with the date like 2006-12-28.rtf and I want to rename them with another date format.
yyyy-dd-mm into dd-mm-yyyy
Does someone know how i can do this?
Thanks for your answers wink
Loulia
#2 2007-01-14 14:19
Re: Rename file formating date expression (yyyy-dd-mm to dd-mm-yyyy)
Hi Loulia,
I think you made a little bobo... you wanted yyyy-dd-mm into dd-mm-yyyy, but the sample file 2006-12-28.rtf that you game is actually in yyyy-mm-dd format, unless there are 28 months in your calendar wink
Anyway, you problem is easily solvable with the RegEx rule:
Expression:  (\d.*)-(\d.*)-(\d.*)
Replace:      $3-$2-$1     or     $2-$3-$1
,depending on the real format of your files. (with skip extension option)
#3 2007-01-14 14:46
Loulia
You and your renamer are the best !
Thanks for your quick answer
