Hello... Renamer is such an awesome tool and I would like to thank you for your effort in developing a tool that comes in handy every day!
Could you add the ability to read the "meta data" (i'm not sure of the correct term) of android APK files in order to rename them with possibilities of the of the following fields: Package / Application / VersionName
There is an application called APKSpy (http://forum.xda-developers.com/showthr … ?t=1115021), that does allow renaming, but its options are very limited.
Thanx in advance!
It's possible, but requires a lot of development. Instead, I will suggest finding a command line tool which is able to extract the necessary meta information form APK files, which you then could use inside ReNamer with the help of PascalScript rule.
Guys here could defiantly give you a hand with the script for integrating a command line tool into ReNamer.
