#1 2007-01-05 17:22
thedb
Help numbering files
I have a folder of files where there are 2 versions of each filename - but with different extension e.g:
test.raw
sample.raw
I want to rename the files to replace the original filename with a numerical sequence e.g.
001.raw
002.raw
Any ideas?
Dave
#2 2007-01-10 03:08
Re: Help numbering files
Hi Dave,
Sorry for such a late reply, I've been away for last 2 weeks. Anyway, similar problem have been discussed and solved in this topic: Rename "buddy" files, like .thm, produced by digital camera. You can reuse the script posted in that topic: add only RAW files, set up Incremental Serialization with padding, then add the script below as the last rule BUT uncheck it and only check back on when you are comfortable with the new names. JPG files will be renamed when you press Preview, and then press Rename button to rename RAW files.
Please, try it on some test files first, before applying to the real files, because modifications to the "buddy" files will be done on Preview!
const BUDDY_EXT = '.jpg';
var NewName, Buddy, NewBuddy: WideString;
  Buddy := WideChangeFileExt(FilePath, BUDDY_EXT);
  if WideFileExists(Buddy) then
    NewName := WideExtractBaseName(FileName);
    NewBuddy := WideExtractFilePath(FilePath) + NewName + BUDDY_EXT;
    WideRenameFile(Buddy, NewBuddy);
