OK boys and gals it's time to rock and roll. Please use and abuse this code but do report any bugs. Thanks.
This script capitalizes the first letter found in a file/folder title regardless of what precedes the letter. The remainder of the title remains unchanged.
i: Integer;
istop: Integer;
FileNameExt: WideString;
i := 1;
istop := 0;
FileNameExt := WideExtractFileExt(FileName);
FileName := WideExtractBaseName(FileName);
repeat
if IsWideCharAlpha(FileName[i]) then // Is the file name character a letter?
istop := 22222;
end
else
i := i+1;
if i > Length(FileName)-1 then istop := 22222;
until (istop = 22222);
FileName := WideCopy(FileName, 1, i-1) + WideUpperCase(FileName[i]) + WideCopy(FileName, i+1, Length(FileName)-1) + FileNameExt;
The second release is a Smart Title Case Capitalizer where the user can choose to force lowercase on certain classes of words e.g. prepositions. Copy the following code to a txt file, save and close file then change .txt to .rnp. Lastly place file in Presets folder.
[Rule0]
ID=Case
Config=WHAT:3;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:0;FRAGMENTSTEXT:then%2Cneither%2Cthere%2Chere%2Cnever%2Coften
Marked=1
[Rule1]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:of%2Cby%2Cto%2Cfor%2Cwith%2Cat%2Cfrom%2Cafter%2Conto%2Cover
Marked=1
[Rule2]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:that%2Cand%2Cbut%2Cor%2Cnor%2Cif%2Cthan
Marked=1
[Rule3]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:he%2Cshe%2Cit%2Cyou%2Cher%2Chim%2Cthey%2Cthem
Marked=1
[Rule4]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:the%2Can%2Ca
Marked=1
[Rule5]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:us%2Cme%2Cour%2Cwe%2Cthis
Marked=1
[Rule6]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:is%2Care%2Cbe%2Chas%2Chave%2Ctill%2Chad
Marked=1
[Rule7]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:all%2Cno%2Cnear%2Cyes
Marked=1
[Rule8]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:on%2Cin%2Cas%2Cso%2Cfar%2Ctoo%2Cup%2Cout%2Coff%2Cnot%2Cyet
Marked=1
[Rule9]
ID=Case
Config=WHAT:0;SKIPEXTENSION:1;EXTENSIONALWAYSLOWERCASE:0;FORCECASE:1;FRAGMENTSTEXT:then%2Cneither%2Cthere%2Chere%2Cnever%2Coften
Marked=1
[Rule10]
ID=PascalScript
Config=SOURCE:var%0D%0A++i%3A+Integer%3B%0D%0A++istop%3A+Integer%3B%0D%0A%0D%0Abegin%0D%0A++i+%3A%3D+1%3B%0D%0A++istop+%3A%3D+0%3B%0D%0A+++%0D%0A+repeat%0D%0A++++if+IsWideCharAlpha%28FileName%5Bi%5D%29++then++++++%2F%2F+Is+the+file+name+character+a+letter%3F%0D%0A++++++begin%0D%0A++++++%0D%0A++++++istop+%3A%3D+22222%3B%0D%0A++++++end%0D%0A%0D%0A++++++else%0D%0A++++++i+%3A%3D++i%2B1%3B+%0D%0A+++++++++%0D%0A+until+%28istop+%3D+22222%29%3B+%0D%0A%0D%0AFileName+%3A%3D+WideCopy%28FileName%2C+1%2C+i%2D1%29+%2B++WideUpperCase%28FileName%5Bi%5D%29+%2B+WideCopy%28FileName%2C+i%2B1%2C+Length%28FileName%29%2D1%29%3B%0D%0A%0D%0Aend%2E
Marked=1
