#1 2012-06-14 18:30
April
Rearranging with more than 9 pieces?
Hello all!
I'm extremely new here, but I've been using Renamer for a couple of years (and I absolutely love it!)
My question is on the rearrange function.  How can I use it if my file name has more than 9 pieces?
For example, this is my file name:
August Derleth - Solar Pons - The Adventure of the Late Mr. Faversham
I want it to be last name, first name - series - title.
The problem is, if I use a space as the delimiter, and tell it to go $2, $1 $3 $4 $5 $6 $7 $8 $9, I get
Derleth, August - Solar Pons - The Adventure of
Is there a way to rearrange names with more than 9 pieces?  Or to tell it to only go as far as the first dash?
Thanks so much!
April
#2 2012-06-14 20:07
Re: Rearranging with more than 9 pieces?
You need to use "Exact pattern of delimiters" option, split using " | ", new pattern "$2, $1 $3".
This basically means that you have 3 parts in the filename which are separated by spaces.
#3 2012-06-14 20:32
April
It works!!!  Thank you so much!
#4 2012-06-14 20:34
Let me explain it to myself so i can understand it too (i still have my problems with "Exact pattern of delimiters")
with
"(o) Exact pattern of delimiters"
means:
Two delimiters split the string into three parts at the first and then at the second found space.
So i will get this three parts:
"August" + "Derleth" + " - Solar Pons - The Adventure of the Late Mr. Faversham"
I can access the first matched part by $1, the second by $2, and the last one by $3.
Then i rearrange this matches parts in the New Pattern field as
$2, $1 $3
OK, works. I got it. (for now. let's see tomorrow big_smile )
Thanks Denis.
