#1 2012-03-26 18:17
chuckster
Adding minutes to the HoursSpan pascal script
I'm not a coder and was wondering how to add a minutes +- variable to the hoursspan script as well as the existing hours variable.  I'm trying to syncronize photos taken fron several cameras that have different internal clock settings.  This tool works great for everything else.
#2 2012-03-26 20:32
chuckster
Re: Adding minutes to the HoursSpan pascal script
I stumbled around and figured out how to make it work.  Maybe you should update your script as well.
// This script reads dates from filenames in format: yyyy-mm-dd hh-nn-ss.JPG
// then adds/subtracts N hours and/or minutes from the date and prints the new date in the
// format defined by DateOutputFormat variable. HoursSpan variable defines
// how many hours should be added/subtracted (use minus for subtraction).
// MinutesSpan variable defines how many minutes should be added/subtracted
// (use minus for subtraction).
  HoursSpan = 0;   // amount of hours to add or subtract!!
  DateOutputFormat = 'yyyy-mm-dd-hh-nn-ss';  // output date format!!
  HoursPerDay = 24;  // do not change this!!
  MinutesSpan = 0;   // amount of mins to add or subtract!!
  MinsPerDay = 1440;  // do not change this!!
  iYear, iMonth, iDay, iHour, iMin, iSec: Integer;
  Date, Time, DateTime: TDateTime;
procedure AddMinutes(var ADateTime: TDateTime; const ANumberOfMinutes: Integer);
   ADateTime := ((aDateTime *MinsPerDay) +aNumberOfMinutes) /MinsPerDay
procedure AddHours(var ADateTime: TDateTime; const ANumberOfHours: Integer);
  ADateTime := ((ADateTime * HoursPerDay) + ANumberOfHours) / HoursPerDay;
  // extract date-time variables as integers
  iYear  := StrToIntDef(Copy(FileName, 1, 4), -1);
  iMonth := StrToIntDef(Copy(FileName, 6, 2), -1);
  iDay   := StrToIntDef(Copy(FileName, 9, 2), -1);
  iHour  := StrToIntDef(Copy(FileName, 12, 2), -1);
  iMin   := StrToIntDef(Copy(FileName, 15, 2), -1);
  iSec   := StrToIntDef(Copy(FileName, 18, 2), -1);
  // process only if all variables are correctly converted
  if (iYear >= 0) and (iMonth >= 0) and (iDay >= 0) and
     (iHour >= 0) and (iMin >= 0) and (iSec >= 0) then
    // create a new date-time variable
    Date := EncodeDate(iYear, iMonth, iDay);
    Time := EncodeTime(iHour, iMin, iSec, 0);
    DateTime := Date + Time;
    // add hours (use minus for subtracting)
     AddMinutes(DateTime, MinutesSpan);
     AddHours(DateTime, HoursSpan);
    // concatenate the rest of the filename and the new date
    FileName := Copy(FileName, 20, Length(FileName));
    FileName := FormatDateTime(DateOutputFormat, DateTime) + FileName;
  end
  // something went wrong
  else FileName := 'INVALID INPUT';
#3 2012-03-27 10:18
You could have used:
DateTime := EncodeDate(iYear, iMonth, iDay) + EncodeTime(iHour, iMin, iSec, 0);
DateTime := IncHour(DateTime, HoursSpan);
DateTime := IncMinute(DateTime, MinutesSpan);
#4 2012-03-27 14:40
I received a reply on my mailbox, I'll reply here.
What I was refering to is replacing your functions for the default ones just like in the code below.
But if your code was already working you could keep using it as it was
  end
