#1 2012-02-17 16:19
cergo
Characters issues with Hooker
Hi and thanks for your great work.
I'm from canada and my keyboard is set as french canadian. When i use Hooker and i start to work as usual, i have issue with characters like ç, â, ä, and others. When i type them the result is: ¸¸c, ^^a, ¸¨a and of course they are not logged properly. Is there anything you can do to fix that ?
Thanks again.
Cergo.
#2 2012-02-18 21:01
Re: Characters issues with Hooker
The Hooker is a legacy application, I no longer develop it. I can't help you I'm afraid.
