#1 2006-10-26 22:35
jay
Rename photo with Date
Hi, is it possible to rename photos (jpg) with date stamp extracted from EXIF.
Example: photoname_date.jpg
thanks
#2 2006-10-27 16:26
Re: Rename photo with Date
Yes, Jay, it is possible!
Do you know about Meta Tags that ReNamer supports? Find a little button with an icon of a lightning in the Insert rule. Click on it, and a "Meta Tags" dialog will come up. Choose EXIF_Date (or/and EXIF_Time) from that dialog and use them in the Insert rule. The format for the date can be defined in the Settings.
Good luck smile
