#1 2006-10-26 09:49
supergirl
Internet / network activity event
I love Shutter, its great....anywayz, is it possible to add: shutdown whenever theres no internet/network activity after a period of time. useful when connection  drops when downloading through the night. tell me what u think. thank u big_smile
#2 2006-10-27 16:22
Re: Internet / network activity event
Good to hear that smile
Would you believe that before the time of your post I was unable to add that event due to insufficient amount of information on actual implementation of the network monitoring? After your post, I did a bit of research once again, and guess what?! I found just enough information to implement this event. Good news: I will add it! Bad news: it will take some time, because the first item on the to-do list is the redesign of the Shutter's functionality and interface, in order to support usage of multiple-events at once.
#3 2008-07-04 06:39
gorash
Is this feature still considered for Shutter 3?
#4 2008-07-07 14:47
Yes, this feature has just been implemented in the Shutter 3 Beta: ShutterBeta.zip
#5 2011-03-25 12:04
creativeImpulse
Hi All,
I am currently putting together a headless microserver and I'm pondering with the idea of wake on network activity hooked up with a shutdown when there is no activity for a significant period.
Would shutter cover this? It sounds like I may have found my solution...
Cheers,
Rob
#6 2011-03-25 15:16
It can't do the first part (waking computer) but it sure can put it to sleep when network transfers are below a certain threshold.
