#1 2006-10-24 19:05
andreone
enter key and edit with spin-control "issue"
This more a misfunction than a real bug.
When a rule dialog is opened, pressing the enter key validates the rule and closes the dialog.
But this doesn't work when the focus is in an edit-box with spin-control.
Should not be hard to fix.
#2 2006-10-25 13:58
Re: enter key and edit with spin-control "issue"
Hi andreone!
You are right, it's not a bug, it is just the way this component works.
I agree, it shouldn't work like that, and so I changed it smile
#3 2006-10-26 00:51
andreone
It works fine now,
