#1 2006-05-16 18:18
vancoovur
Remove spaces?
Can Renamer remove spaces from file names? Ifso, how do I go about that?
#2 2006-05-16 20:43
Re: Remove spaces?
Yes, of course it can! smile
One question first, do you want to remove ALL the spaces? or only duplicate spaces?
All spaces can be removed simply using the "Remove" rule, and enter a SPACE in the edit field.
Duplicated spaces can be removed using the "CleanUp" rule, use option called "Fix spaces".
#3 2006-05-16 23:43
vancoovur
Re: Remove spaces?
Thanks...I knew it was in there somewhere. :yes:
