#1 2006-10-17 16:50
pdv
Time of "Low CPU Usage"
Hi Denis,
this is another topic from my wishlist: I'd like to have a longer period of time for "Low CPU Usage".
As I understand. the maximum time is 999 seconds (approx. 17 minutes).
We'd like to shut down our systems after 60 / 120 Minutes. Is there a solution?
Regards, Heribert
#2 2006-10-18 18:24
Re: Time of "Low CPU Usage"
Heribert, I've increased maximum length of the number of seconds in Low CPU Usage event.
Try it from here: ShutterBeta.zip
#3 2006-10-19 17:23
pdv
Sorry, Denis,
I tried your beta, but it still seems to be limited to 999 seconds on event low CPU usage.
Regards, Heribert
#4 2006-10-20 00:08
Sorry Heribert, I forgot to update the arrows-counter! If you would have entered the number of seconds manually (not using the arrows), you would be able to specify a maximum of 999999 seconds. I've update the arrows-counter, so it can go to the maximum of about 32000 seconds. ShutterBeta.zip is updated!
Later, I will be changing the interface of Shutter, in order to support usage of multiple events at once. I should be adding minutes and hours fields for this event..
