#1 2011-12-05 00:41
anjulz
Shutter wont save data in options
I dont know what Im doing wrong, but when I check the boxes I prefer & then click save it pops up a box that says it cant save my data. Has not been working...can you help?
#2 2011-12-05 08:09
Re: Shutter wont save data in options
Which OS? The problem could be that you've installed it in Program Files, which is made read-only by Windows due to security reasons.
#3 2011-12-12 06:43
lrodrigu70
Same thing happened to me.  I downloaded the beta 2011-11-26 zip file.  I copied the shutter.exe program to a folder but I didn't copy all the other files that came with it (shutter.ini and inactivity.dll) to the same location.  Once I did that, the settings saved OK.
Hope this helps.
