I'm hoping someone can help me with my file naming issue. I need to remove repeat instances of a string in my file name. For example:
spanx_women_spanx_underwear.psd (I work for a fashion retailer)
I'd like to be able to remove the second instance of 'spanx", or any repeat alphabetic string, from my file name. I'd like it to look like this:
spanx_women_underwear.psd
I believe the solution is with a regex rule, but I am new to ReNamer and have less experience. could someone please help me?
Also please note that the first instance of "spanx" is being added with an Insert: ":File_FolderName:" rule. "spanx" is the name of the parent directory.
Thanks so much!
How can i get the wanted string to remove?
Is there an rule?
Every time the first word till the first underscore?
Or simpler: every time the word between second and third underscore?
Have you a few more examples?
Well, I have a general script for this...
Maybe it could get better but it works for me:
Part: TStringsArray;
Ext, LastSeparation: WideString;
I1, I2: Integer;
// TAKE ALL PARTS (GOOD AND BAD)
Part := MatchesRegEx(WideStripExtension(FileName), '([^A-Z]+|[A-Z]+)', False);
// EMPTY NAME TO REBUILD LATER
FileName := '';
// GO TROUGH EVERY WORDS
LastSeparation := '';
for I1:=0 to length(Part)-1 do begin
if (Part[I1] = '') then Continue;
// REMOVE EVERY REPEATED WORD
if length(MatchesRegEx(Part[I1], '^[A-Z]+$', False))>0 then begin
for I2:=I1+1 to length(Part)-1 do if WideSameText(Part[I1], Part[I2]) then Part[I2]:='';
end else begin
// CLEAN REPEATED SEPARATORS ALSO
if (Part[I1] = LastSeparation) then Part[I1] := '' else LastSeparation := Part[I1];
// REBUILD FILE NAME
FileName := FileName + Part[I1];
FileName := FileName + Ext;
EDIT: Updated to clean the separators better
SafetyCar,
That worked almost perfectly! Thanks!
One thing I wanted to ask - The pascalscript you wrote isn't removing numbers in the repeated string. So:
2byrch_women_2byrch.psd
2xist_men_2xist.psd
525america_men_525america.psd
turn into:
2byrch_women_2.psd
2xist_men_2.psd
525america_men_525.psd
What I'm hoping is that the files will turn into:
2byrch_women_.psd
2xist_men_.psd
525america_men_.psd
What should I add to your pascalscript that will include the numerical part?
Thanks!
Emmm, about including digits...
I see it a little more dangerous for a normal use, because it could delete unwanted numbers.
Anyway, taking some care you could do it replacing this 2 things:
Part := MatchesRegEx(FileName, '([^A-Z]+|[A-Z]+)', False);
with
Part := MatchesRegEx(FileName, '([^A-Z0-9]+|[A-Z0-9]+)', False);
with
if length(MatchesRegEx(Part[I1], '^[A-Z0-9]+$', False))>0 then begin
Wait... To not match single numbers (without text), here is a safer way:
I1, I2: Integer;
FileName := '';
if length(MatchesRegEx(Part[I1], '^[0-9A-Z]+$', False))>0 then begin
if length(MatchesRegEx(Part[I1], '^[0-9]+$', False))=0 then begin
end else begin
