Hi Denis,
Usually I need to use a preset and then add some rules to tackle the current batch of files.
This modified set is not useful when I launch the ReNamer again for a different set of files.
Therefore I have to launch the ReNamer without any rules and load the same preset manually each time.
I think this is a common scenario.
Please allow the user to load a preset when ReNamer is launched.
The new settings could be as follows:
[x] Load the following rules when ReNamer is launched:
O Reload the rules that were used in the last session.
O Reload a preset (select from available list)
The [x] is a check box, and the O is a radio button.
Thanks in advance.
You can create a shortcut which will always load a specified preset, for example:
"ReNamer.exe" /preset "Preset Name"
Sure that is one way. That requires argument for the verb, though.
How about a built-in facility, for the not-so-advanced users?
For not-so-advanced users I've created a "Create Links" option in the Presets menu
oh yes! How I could I forget that!
