#1 2011-10-07 15:14
LestatRM
"Resume events when PC wakes up" doesn't work
I'm using shutter (beta) and I find it very useful!
But there is a problem:
it correctly puts PC in sleep mode, but when I wake up the computer, Shutter is in "stop mode", the tray icon is gray
obviuosly I selected the option "Stop events when computer is going to hibernate/sleep and resume when computer wakes up"
is it a bug?
Best Regards
#2 2011-10-08 14:59
Re: "Resume events when PC wakes up" doesn't work
It might be something specific to your system. Which version of windows are you using?
In the meantime, try the official release of Shutter 2.90 to see if it works.
#3 2011-10-09 16:26
LestatRM
I use Win 7 32 bit on a Zotac Hd-Nd21
Are Shutter's setting located only in shutter.ini?
Because the line "StopOnSuspendAndRestartOnWakeUp=1" is correctly present
Ok, but the official release doesn't have the event "Network traffic", isn't it?
#4 2011-11-06 16:25
Yes.
Correct.
