#1 2006-10-06 11:52
JJ
Renaming jpeg files
Trying to rename photos within a folder.
Want to rename as 1.jpeg, 2.jpeg and so on.
Currently named in format 110_1093.JPEG, 110_1094.JPEG and so on.
Please advise.  Please assume I don't know anything!
Thank you in anticipation.
#2 2006-10-06 12:42
Re: Renaming jpeg files
First step is to drag and drop your folder with photos into ReNamer. Make sure you remove windows thumbnails (*.db files) from the files table, if there will be any, by selecting them and pressing Delete key.
Then, you need to add these 3 rules:
1) Delete: from position 1, until the end;
2) Serialize: incremental, start 1, step 1, as prefix;
3) Case: all lower case, do not skip extension.
Preview, Rename, and you are done!  smile
P.S. if you want to preserve their original numeric order, right-click on the files table columns and pick a "Name Digits" column from the popup menu, to show this extra column. Then, left-click on that column to sort by the digits in the name.
