#1 2011-09-25 18:27
homer
Option to insert filenames in given position
Hi Denis!
    First of all, i'd like to congratulate you, 'cause renamer is an AMAZING piece of work!
It really saved me a lot of time! thanks a lot for this!
Now, let me get to the point : i was renaming some files the other day, and had to insert some words i had saved in a text file.
so i added a rule, went to userinput and opened the file. But the thing is, that i wanted to insert these words somewhere in the middle of the current file name, not in front of the current name, not after the current name, but somewhere in the middle. Can you provide an option to insert the new names in a user-selectable position?
i know i can do it now, by inserting the new part either in front or at the end, and then move it where i want. but having the option described above would be more straightforward.
thank you in advance
#2 2011-09-25 20:39
Re: Option to insert filenames in given position
Hi.
I think this scenario might be a bit too specific to add it to general rules.
Do you need a hand with movement of the inserted part?
#3 2011-09-25 22:42
homer
i understand. i just thought it would be handy, though, that's why i made the suggestion. smile
thank you for offering to help, but i know how to move the part
thanks again for your quick reply! smile
