#1 2011-09-19 18:25
EsbenRasmussen
Using serialize: Increment if folder changes
Hi I am about to rename 8 different folders containing a tv series.
In all 8 of those folders I need to add "SZZEXX" to all the files.
In folder 1 the first show would be "S01E01" and the second would be "S01E02".
In folder 2 the first show would be "S02E01" and the second would be "S02E02" etc.
What I really need is a tickbox similar to "Reset if folder changes" that says "Increment only if folder changes".
If such a tickbox was available, it would be a simple operation to make ZZ increment when the folder changes and let XX incremement for each file in the folder - and reset it, when the folder changes.
If this is added this program fits all of my needs!
Oh, and if this is already possible and I just haven't looked close enough then please feel free to reveal how to do it: Stefan was very helpful and posted a (hopefully temporary) solution using PascalScript: http://www.den4b.com/forum/viewtopic.php?pid=5954
/Esben
#2 2012-02-20 23:52
AndrewRH
Re: Using serialize: Increment if folder changes
Yes, that would be the option I'd love to have. Here's my vote for that! Will try to PascalScript solution for now...
