#1 2011-06-13 03:36
cronos
Change from DDMMYYYY to YYYYMMDD
Sorry for my English.
Hi I would like to know how to change above subject.
I have files something like this:
MyWordSchedule-23-04-2011-Rev.1.0.doc
And i would like change to:
WordSchedule.Rev1-2011-04-23.doc
How I able to do that?
If possible to have a guide screenshot how to do it?
Thank you.
#2 2011-06-13 18:44
Re: Change from DDMMYYYY to YYYYMMDD
Hi and welcome cronos
MyWordSchedule.Rev1-2011-04-23.doc
You can use Regular Expressions > http://www.den4b.com/wiki/ReNamer:Rules:RegEx
Or use the Rearrange Rule from the latest ReNamer beta > http://www.den4b.com/wiki/ReNamer:Rules:Rearrange
See   Example 1,Task: Swap parts of name at > http://www.den4b.com/wiki/ReNamer:Rules … e_Examples
Tip: Press Shift+A to see the Analyze window
      where you can paste in your example string(s) and see what happens by applying the rules.
      This way you can test all you want without messing up your real files.
For your example
use Rearrange, Split using Delimiters "-"
which gives you this parts
$1 = MyWordSchedule
$2 = 23
$3 = 04
$4 = 2011
$5 = Rev.1.0
You can test this by using the following as "New Pattern":
$1 \ $2 \ $3 \ $4 \ $5 \ $6 \ $7 \ $8 \ $9
Which gives you:
MyWordSchedule \ 23 \ 04 \ 2011 \ Rev.1.0 \  \  \  \ .doc
For your example rearrange them in the output "New Pattern" like:
$1.$5-$4-$3-$2
to get:
depends how you want this.
For example you can use Rule Delete to delete the first two signs.
All in all you have to use two rules here:
1) Rearrange: Split by delimiters "-", New pattern "$1.$5-$4-$3-$2" (skip extension)
2) Delete: Delete from Position 1 until Count reaches 2 (skip extension)
