#1 2011-05-07 09:45
ttzo7l51db
Shutter & ReNamer option to change numbers with mouse wheel
Where in controls have option to change numbers by UP or DOWN suggest to have also option to change numbers by mouse wheel
#2 2011-05-07 10:42
Re: Shutter & ReNamer option to change numbers with mouse wheel
If you are talking about switching the order of the items in the lists then you can do this by using CTRL+UP and CTRL+DOWN. Mouse wheel is generally used for scrolling the list and it would be unintuitive to switch this behaviour for something else.
#3 2011-05-07 11:04
ttzo7l51db
No, I talking about any place in windows gui that have UP and DOWN buttons, example:
#4 2011-05-07 15:47
eR@SeR
I know that this was discussed here a long time ago but never answered. I'm for it. Cheers wink
#5 2011-05-07 16:18
ttzo7l51db
Probably this option not supported/limited by programming software.
#6 2011-05-21 22:54
Milrem
I thought about that long ago. I'm for it too. And it's intuitive.
Cya
"The unexamined life is not worth living."
                                                  Socrates, Sec. 38
#7 2011-05-22 14:25
narayan
Yes, that would be nice to have.
Just to clarify the logic:
In case of timer, we should be able to use mouse wheel on all three figures (HH MM SS) individually.
  • After MM reaches 60, it either recycles back through 00 or stays at 60. But does not have any effect on HH.
