#1 2006-09-20 11:45
willz
Striping Out Prefix Numbers
Hello there
I would like to start by saying I have been looking for a program like this for ages, I?m well pleased with it.
But my questions is this, I have a load of files all names in numerical order like this
0001 - Afilename.zip
0002 - Bfilename.zip
0003 - Cfilename.zip
But I need to get rid of the numbers and spacers at the beginnings so they will sort in alphabetical order.
any help will be great
cheers,
#2 2006-09-20 14:48
Re: Striping Out Prefix Numbers
Hi willz smile
To do that you can simply use Delete rule: from position 1 until delimiter "-" (dash). This will remove everything from the beginning to the first dash, including the dash it self. To fix up the spaces, use CleanUp rule: fix spaces option. There are also few other very sophisticated ways of doing the same thing - using RegEx or PascalScript rules, but these 2 steps above should do the job.
Denis.
