#1 2011-02-08 09:22
RoSi
Change to UPPERCASE before " - " ?
can somebody help me with Pascal Script that will rename everything in filename before " - " to UPPERCASE?
Thanks.
#2 2011-02-08 16:37
Re: Change to UPPERCASE before " - " ?
I have not searched the forum -there should be already threads about this issue-, but just paste you an script:
//From "Band Name - Song Title.mp3" to "BAND NAME - Song Title.mp3"
  Artist, Title, EXT: WideString;
  //////             Split file name at the first dash into to parts:
  //////Artist is "Band Name"
  Artist := ReplaceRegEx(WideExtractBaseName(FileName), '(.+) - (.+)', '$1', False, True);
  //////Title is "Song Title"
  Title  := ReplaceRegEx(WideExtractBaseName(FileName), '(.+) - (.+)', '$2', False, True);
  //////Extension is "mp3"
  EXT :=  WideExtractFileExt(FileName)
  //////             do the case conversions:
  //Artist := WideCaseCapitalize(Artist);
  Artist := WideUpperCase(Artist);
  //Title := WideCaseCapitalize(Title);
  //EXT := WideLowerCase( EXT);
  //////           build the new filename:
  FileName := Artist + ' - '  + Title + EXT;
Here is an other approach with using ID3 tags >>> http://www.den4b.com/forum/viewtopic.php?id=312
And then i found ( ;-) ) this too >>> http://www.den4b.com/forum/viewtopic.php?pid=4873#p4873
HTH? big_smile
#3 2011-02-09 11:04
SDdave
Try this:
{ This script converts all characters left of first " - " to upper case }
Var
   ParsedFilename: TStringsArray;
Begin
   ParsedFilename := WideSplitString(WideExtractBaseName(FileName), ' - ');
   FileName :=  WideReplaceStr (FileName, ParsedFilename[0], WideUpperCase(ParsedFilename[0]));
End.
#4 2011-02-09 13:39
This script would be a better alternative and more efficient:
  I: Integer;
  I := WidePos('-', FileName);
  if I > 0 then
    FileName := WideUpperCase(WideCopy(FileName, 1, I - 1)) +
      WideCopy(FileName, I, WideLength(FileName) - I + 1);
P.S. SDdave's script will work in most cases, but will also convert to upper case all occurrences of the "pre dash" part in the entire filename, if it occurs more than once.
#5 2011-02-09 18:01
I also put up two scripts on to Wiki to demonstrate the partial case change:
ReNamer:Scripts:Partial_case_change
