#1 2006-09-01 18:22
chris
Rename multiple folders
Hi I'm trying to rename folders within a folder the structure is
E:\ospdata\01-jan-06\machine_xx\input_xx\09.00.00.000\audio.wav
I need to rename all instances of machine_xx to machine_yy but there are over 6,000,000 files within the ospdata folder and when I add the folder "ospdata" and subfolders as file the memory usage goes through the roof and the server hangs.
Is there a limit on the number of folders that can be processed/renamed?
#2 2006-09-01 21:34
dloneranger
Re: Rename multiple folders
I just tested a much smaller set of folders (6615 folders, 449817 folders) and it only took a few seconds to load them in
Memory usage grew by 2meg
Scaling that up - the memory usage should be about 24Meg ?
Check that you have the latest version and that in the settings, on the general tab - 'Default behaviour for adding folders' is set to 'Add folders as files'
That's all I can suggest off hand
[edit]
apart from
antivirus software - tryy turning it off temporarily, or excluding .wav from the files it checks
[edit2]
In the settings
preview tab - untick 'Resort table when files are added' and 'Validate new filenames on preview'
Meta tags tab - untick 'Meta tag support'
#3 2006-09-04 13:03
Hi chris,
No, there is no limit, apart from the top on the integer: 2,147,483,647 - don't go over that number, results will be unpredictable wink . The only thing you should be conserned about is the time, do take the steps advised by dloneranger, they will speed up the processing...
Good luck!
