#1 2010-10-26 15:22
drMerry
Regex upper/lower case using \u \U \E \l \L \E
I wanted to make some changes to my directories.
If I try to change my directory this way:
(Selected folder = ..\myDir)
regex: (.)(.*)
replace: \u$1\\$1$2
result: ..\um\myDir
I expected
..\M\myDir
also using \U$1\E\\$1$2 did not work
Is this function not implemented?
Is there a way to use renamer with uper/lower case functions in regex?
(I know there is an option to upper/lower case my folders, but I have a structure that does not let renamer case my files correctly, I need a regex. It is also no option to rename the folder to start with uppercase, it must stay in the case it is)
#2 2010-10-27 15:03
drMerry
Re: Regex upper/lower case using \u \U \E \l \L \E
And another one about regex, is also problematic.
when a folder has a dot in it's name and skip extensions is turned on, renamer thinks the folder has an extension.
On files this is usefull, not on folders (or is it?)
#3 2010-10-28 07:00
ozzii
On folder you must use "skip extension".
I have to use this for the same reason.
_________________
#4 2010-10-31 13:49
It is a known limitation of the current RegEx engine: "\u \U \l \L" are not supported. Here is a topic which also talks about this limitation and describes an alternative solution using PascalScript: ReNamer: RegEx missing features.
#5 2010-10-31 17:40
Here are examples of PascalScripts which use RegEx to split the string into parts
and then use script commands to change the case:
ReNamer: first part with Title, second part uppercase, third as it is
HTH
