#1 2010-10-25 11:00
bucko
Can't access web interface when computer goes to Sleep
I just started to try shutter and I like its features. However I do have a problem.
I am running Win 7 on my PC. On the lan I can bring up the Shutter interface fine and send a command (sleep). The receiving PC goes to sleep fine. But once sleeping, I cannot open the SHutter interface again (website not available). I have portforwarded my router ok. CanUseeMe shows the port is open, but not Shutter GUI shows.
Is there another router setting I am missing? Maybe PC setting? BTW, my PC is setup to login in after sleep. Is this ok?
#2 2010-10-31 13:43
Re: Can't access web interface when computer goes to Sleep
When computer goes into suspended mode (Sleep or Hibernate) all running applications are suspended too. You can think of it as if your computer has been turned off. That is why you can't access Shutter's interface.
