#1 2009-02-25 18:09
phreaq
Renaming Children Folders with Parent Name
Hi Folks,
I am trying to rename a series of folders, but I'm not sure how to do it, since metadata isn't available for folders.
My current structure is:
c:\artist\album\[contents]
I want to combine the names so that I get a folder name of "artist - album".
I suspect my final folder structure would look like this (c:\artist\artist - album\[contents]), which is fine, I'll just drag the children to the root.
any help is appreciated,
thanks in advance,
#2 2009-02-25 19:16
krtek
Re: Renaming Children Folders with Parent Name
Take a look on that topic. It might be useful.
#3 2009-02-25 20:02
phreaq
thanks for the reply krtek
I did see that post, but it's using information from the first file to populate the folder prefix. My files don't have the parent folder information stored in them, so I cannot pull any data from the file itself.
or am I missing something?
#4 2009-02-28 13:10
You can use :File_FolderName: meta tag to access parent folder name.
So in your case, when you added your folders as files for renaming, add Insert rule: ":File_FolderName: - ".
#5 2009-03-03 14:21
phreaq
I tried using the  option, but I'm not getting the results I want. I just get " - album name", no artist info
Where is it trying to get the meta data from? I don't have any files in the folders that have meta data info.
#6 2009-03-03 14:55
krtek
Hmmm... I have reproduced that result.
It seems that :File_FolderName: works only for files and not for folders...
#7 2009-03-03 14:58
The metatags don't work for folders roll roll roll
#8 2009-03-03 15:04
krtek
You can try to use this simple PascalScript for that job:
Path, SubFolders : TStringsArray;
Depth : Integer;
  if not WideFileExists(FilePath) then
    SetLength(SubFolders,0);
    Path:=WideSplitString(FilePath,'\');
    WideScanDirForFolders(FilePath, SubFolders ,True, False, False);
    Depth:=Length(Path);
    If (Depth>1) and (Length(SubFolders)=0) then
      FileName:=Path[Depth-2]+' - ' + Path[Depth-1];
Script will omit files and will proceed only the deepest folders.
#9 2009-03-03 15:49
phreaq
Depth : Integer;
dude, you rock. that does the trick
it's been a while since I used pascal, thanks for your efforts.
#10 2009-09-16 22:55
alext
I'm really struggling with something which seems very related to this but since I don't understand pascal I don't know how to modify this script for my needs.
Basically, I have songs files in a big folder in the format "Artist - Song.mp3". I want to rename them so that all the songs by the same artist appear in separate folders. ie I want to have "Artist/Song.mp3".
Please can you help. I know this must be simple but I've been searching the forum for ages and still have no idea.
Thanks!
