#1 2024-09-09 10:29
Lauraq
It is possible to delete all the text before "S**E" ?
Hi smile
In reference to the previous post, I noticed that many TV series also divide the title in this way:
The.Big.Bang.Theory.S09E01.Il.Momentum.iTA.ENG.DLMux
or
The.Big.Bang.Theory.S19E01.Il.Momentum.iTA.ENG.DLMux
I would always like to remove all the part that does not concern the title and the number, so have only:
01 - Il Momentum
Is it possible? Thanks smile
#2 2024-09-09 17:28
Jaaacky
Re: It is possible to delete all the text before "S**E" ?
Hi smile
Rules :
1) Retirer(remove) tous "The.Big.Bang.Theory.S??E" (sauter l'extension)
2) Retirer tous ".iTA.ENG.DLMux" (sauter l'extension)
3) Remplacer tous avec " - " (sauter l'extension)
! Il faut ajouter un compteur sinon : doublons !
4) Sérialiser: Incrémentiel à partir de 1 répéter 1 pas 1 comme suffixe (sauter l'extension)
Results :
01 - Il - Momentuml .txt
01 - Il - Momentum2.txt
01 - Il - Momentum3.txt
#3 2024-09-09 19:38
Lauraq
thanks, I didn't understand anything but thanks smile
I would like to point out that the part after the title is too variable and therefore it is not possible to automate everything.
What interests me is the first part
#4 2024-09-09 22:34
Try these rules:
1) Regular Expressions: Replace expression "\A.*\bS\d\dE(\d\d)" with "$1 -" (skip extension)
2) Remove: Remove all ".iTA.ENG.DLMux" (skip extension)
3) Replace: Replace all "." with " " (skip extension)
They will convert this...
  The.Big.Bang.Theory.S09E01.Il.Momentum.iTA.ENG.DLMux.avi
into this...
  01 - Il Momentum.avi
#5 2024-09-10 18:00
Lauraq
it works perfectly, thank you very much!
