#1 2023-01-18 10:20
melvynadam
HUGE ReNamer fan.... moved to MacOS
I've been using ReNamer since around 2005. And I'm a massive fan.
But I've recently left Windows and moved to MacOS.
Can someone please recommend a (preferably free) equivalent utility for MacOS.
#2 2023-01-18 11:13
Re: HUGE ReNamer fan.... moved to MacOS
You can use ReNamer on Mac with the help of platform compatibility software, such as PlayOnMac.
There is more information on that subject on the wiki:
https://www.den4b.com/wiki/Compatibility#Mac_and_Linux
In the long run, ReNamer will run natively on Mac and Linux.
#3 2023-01-18 12:42
melvynadam
Thanks. I'd found that page and tried WineBottler but only got errors.
PlayOnMac worked perfectly! Thank you. I'm now using ReNamer on my Mac and delighted to see the familiar screen as if nothing has changed smile
