#1 2023-01-16 09:53
mikeincairns
Status Bar at bottom of screen
Hi all
I believe the status bar is displaying the total number of files loaded.
Is it possible to display the number of files that will be effected by a rule?
I notice the files are highlighted if they are effected by a rule, but I just need to know how many.
It would be nice to see the total in the status bar.
#2 2023-01-24 15:58
Re: Status Bar at bottom of screen
You can get this information in two steps:
1. Files menu » Mark » Mark only changed
2. Options menu » Count marked and selected files (SHIFT+I)
The number of changed files will be equal to the number of marked files.
#3 2023-01-25 01:02
mikeincairns
Great! Thankyou
