#1 2023-01-13 06:30
mikeincairns
Need to fix duplicate extensions filename.pdf.pdf
I have a lot of files (not all my files) with duplicate extensions, for example...
<filename>.pdf.pdf
Is there an easy way to detect and fix these?
I think they are all pdf's if that helps at all.
Thankyou
BTW - this is awesome software.
#2 2023-01-13 08:33
Re: Need to fix duplicate extensions filename.pdf.pdf
You can do this using the Regular Expressions rule:
Expression: (\.[^.]+)\1+\Z
Replace: $1
Skip extension: NO
This will remove all duplicate file extensions.
I think we can also add a dedicated option for that to the Extension rule in the coming version.
#3 2023-01-13 09:21
mikeincairns
To everyone at den4b
Thankyou.  You are amazing.
#4 2023-02-22 17:19
A dedicated option to remove duplicate file extensions was added in ReNamer 7.4.0.4 Beta.
The new option can be found in the Extension rule.
#5 2023-02-23 06:41
mikeincairns
You guys rock !!
