#1 2013-02-13 00:55
Mountie
Replace only the first two diggits
Hello community,
I downloaded ReNamer and guess it is a wonderful program.
My files are named like this:
Now - I want to replace only the first two characters (99) into wood-99-
The result should like this:   wood-99-1010.jpg
The first time it is wonderful - but after starting the program a second time
and scanning the whole files again - the result will be like this:
How can i define that the program will scan only the first two characters and replace them?
I am sorry about my bad english.  :-(
Hope you'll understand my problem. :-)
Best greetings
Mountie
Wer fragt bleibt einen Moment unwissend, wer nicht fragt sein ganzes Leben.
#2 2013-02-13 01:03
Re: Replace only the first two diggits
Hello Mountie, and welcome!
You can use the following RegEx rule to do that:
* Replace expression "\A(\d+)" with "wood-$1" (skip extension)
This will insert "wood-" only in front of filenames that start with digits.
More information about Regular Expressions available here:
#3 2013-02-13 07:31
Hello, just one little improvement.
The RegEx pattern "\d+" means "one-or-more of a single digit".
This would also find more then two digits, also maybe three or four too.
To make it more perfect i would search for exactly two digits by using "\d\d"
and additionally, to be even more precise,  only if the digits are followed by an hyphen: "\d\d-"
Read: match an leading digit, followed by an second digit and an hyphen.
Use RegEx rule
* Replace expression "\A(\d\d-)" with "wood-$1" (skip extension)
#4 2013-02-13 10:51
Mountie
Hello den4b, hello Stefan,
thanks a lot for the quickly response.
I guess that I explained my problem not exactly.
This are the files: (more different examples)
I want to make such a result:
With \A\d\d-   wood-$1 EVERY filename will be replaced with wood.
I want to create a rule (or more rules) like this:
Rule1
Read the first two charakters.
If charakters= 99- then replace with wood-99-
Rule2
If charakters= 50- then replace with metal-50-
Pascal script? hmm
O.K. - I will read again at the wiki side.
@den4b
The program is very powerful - congratulations to this perfekt work.
Hope to find a solution.
see ya
Mountie
#5 2013-02-13 11:38
Then find and replace literally.
Rule:
search literally for "99-" at the beginning (\A) of an string and replace literally by "wood-99-"
search literally for "50-" at the beginning (\A) of an string and replace literally by "metal-50-"
USE:
1) RegEx: Replace expression "\A99-" with "wood-99-" (skip extension)
2) RegEx: Replace expression "\A50-" with "metal-50-" (skip extension)
3) RegEx: Replace expression "\A33-" with "glas-33-" (skip extension)
4) ...
5) ...
Use "Presets > Save as..." to save this for later use.
Solved?
#6 2013-02-13 11:48
Mountie
Hi Stefan,
oh man - so easy - but I didn't managed it alone.
Now it runs very good. Thanks a lot for your help and your patience. (!)
Have a nice day
Mountie
