need help rename 7k files mkv, vob, avi == NOT a good issue description !
Hi
I have a bout 7k files need to be rename i have done a lot removed now i am stuck on this please help
Anne Murray - You Needed Me want to rename to You Needed Me .Anne Murray
Diem Thu - Hay De Mua Roi want to rename to Hay De Mua Roi .Diem Thu
Thanh Tung - Van Hat Loi Tinh Yeu want to rename to Van Hat Loi Tinh Yeu .Thanh Tung
Tu Qinh - Pho Bien want to rename to Pho Bien .Tu Qinh
hoi
Hi and welcome hoi!
Tu Qinh - Pho Bien
Pho Bien .Tu Qinh
USE e.g. Rearrange Rule:
Rearrange Rule: Split by delimiters " - ", New pattern "$2 .$1" (skip extension)
Explanation:
- Split string into two parts at " - ", store the matches into var $1 and $2
- Create the New Pattern by reorder those stored parts to "$2 .$1", and add the space and dot yourself.
Note: Quote " " are only used for clarification. Don't use them in real.
WIKI for more info:
http://www.den4b.com/wiki/ReNamer:Rules:Rearrange
http://www.den4b.com/wiki/ReNamer:Rules … e_Examples
HTH?
Thanks for your help Stefan I got it Done a lot but haft of the files names ican't be done.
Don't know what i did wrong please help
-from
You Needed Me - Anne Murray
Hay De Mua Roi - Diem Thu
Van Hat Loi Tinh Yeu - Thanh Tung
Pho Bien - Tu Qinh
- I got this
You Needed Me . Anne Murray
Hay De Mua Roi . Diem Thu
Van Hat Loi Tinh Yeu . Thanh Tung
Pho Bien . Tu Qinh
-Wanted
Pho Bien .Tu Qinh
now all files still look like this You Needed Me - Anne Murray
Hi hoi,
if i use
on your examples, i get your -Wanted.
If you really use this rule as shown, you will get
-Wanted
and not
I do not see your problem.
Maybe post an link to an screen shot for clarifying.
I found the problem I need to add rule delete blank in the front of the file name 1st then I can do your step because my files.
I have an other question how to add sequence number in front of 17, 000 files name
I want to say thanks for your times. With out this software it can't be done
hoi
So the challenge was
" Anne Murray - You Needed Me.ext"
"You Needed Me .Anne Murray.ext"
Solved? Fine.
Good work, hoi!
