#1 2006-12-08 12:15
drunk
Swapping words within a file name?
Howdy from Down Under! Great software! big_smile
I'm in the same boat as this guy http://www.den4b.com/forum/viewtopic.php?id=6  well the first two (and last) sentences anyway wink
I often need to rename files by swapping groups of words, either side of a seperator.
Is there any easy way to do this with ReNamer? Like the Swap/Add function in 1-4a Rename?
Visual explanation:
#2 2006-12-08 13:12
Re: Swapping words within a file name?
Yep, there is an easy way: RegEx! smile
Expression: (.*) - (.*)
Replace: $2 - $1
- will switch two blocks around separated by the " - ", e.g.: if input string is "John Smith - Some Song", then output will be "Some Song - John Smith".
Note: if you use any special symbols like "." (dot) as a separator, it will have to be escaped using slash, like this "\.". For more info look at he help in RegEx, or google for Regular Expressions.
#3 2006-12-08 13:48
drunk
Well that was just too easy wink And too bloody quick on the support! yikes
Yeah I suspected the answer may lie within RegEx and did a bit of snooping around, but I'm just not too familiar with the old regular expressions.
Best I get acquainted I guess.
That works perfectly... thanks heaps for your help!
